Activity Forums Adobe After Effects What if the source of a “Laser” is on its back?
  • What if the source of a “Laser” is on its back?
    Posted by Michele Poggi on February 16, 2013 at 3:33 pm
    I’m compositing a laser, this laser is being shot by a little robot that is giving the back to the camera.
    I’m using VideoCopilot Optical Flares to do so, but I didn’t find a way to solve my doubt and problem: when the laser should be hitting the wall in background, the flare reacts as if it was shot TOWARDS the camera.
    5458_example.jpg.zip
    I did mask the light to be behind the little robot but the effects it’s clearly fake, is there any way to tell the Plugin to consider a point to be the source of the light that is pointing towards a given direction?
    “Freelance Post-Producer”
    Editor Video
    Graphic Designer
    Digital Compositor
    Mail: snm.poggi@gmail.com
    Mobile: +39 3349129191
    Skype: sabakunomaiku
    Michele Poggi replied 13 years, 7 months ago 2 Members · 2 Replies
  • John Cuevas
    February 16, 2013 at 6:07 pm
    Lens flares are basically reflected light hitting a camera lens, they always point towards the camera. No way to really turn them around. You will have to play with the options to make a flare that is more subtle to create the realism you are trying to achieve.
    You might want to go with a smaller flare and use the beam effect for the actual laser.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Michele Poggi
    February 17, 2013 at 10:16 am
    Thanks. 😉
    Editor Video
    Graphic Designer
    Digital Compositor
