What & How
Very simple needs, film a long meeting, take the multiple files generated, trim the meeting time-line beginning & end, join the multiple files, and put it on the webpage. Maybe edit out a long pause, or break in the meeting.
While I haven’t settled on an editor yet, the ones I’ve tried (demo versions of Vegas, Adobe, Pinnacle, others) all seem to have sufficient editing tools for my needs.
They are all very slow, and that might be the source file format. Specs below *
The “what” question is with which editor should I settle on as I begin my learning curve?
The “how” question centers around workflow – most of the editors have some assistance on how to edit, however hand holding on rendering to maximize an attribute appears weak. It appears to be trial & error, select one of many options, point, fire, see what happens. This is a lot like my experience with free software – which I hoped to avoid with licensed products.
So, I need an editor that will work with my file format and modest editing needs & shepard me a bit so I don’t get lost in the rendering/format weeds.
Specs:
Me – geek, technical, hands on.
My PC is 4 gig, dual core, 2.5 mhz, Vista 64 SP2
My camcorder Samsung H200 H264/AVCHD mp4
Capture 2/3 hours = 4 or 5 2 gig files.Format : AVC
Format/Info : Advanced Video Codec
Format profile : Main@L4.2
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Format settings, GOP : M=3, N=15
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 35mn 51s
Bit rate mode : Variable
Bit rate : 5 995 Kbps
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 fps
Minimum frame rate : 59.920 fps
Maximum frame rate : 59.960 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.109
Stream size : 1.50 GiB (98%) (one file)
Title : HMX200
Language : EnglishAudio
Format : AAC
Format/Info : Advanced Audio Codec
Format version : Version 4
Format profile : LC
Codec ID : 40
Duration : 35mn 51s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Stream size : 32.8 MiB (2%)
Title : HMX200
Language : English
