Activity Forums Zaxwerks What have i done that is not correct?
  • What have i done that is not correct?
    Posted by Evrard Blom on May 14, 2006 at 3:07 am
    I was trying to create a 3D object in proAnimator (and in invigorator) from an AI file.
    ProAnimator says “there is no usable vector path in your file” and closes.
    How did i create the AI file? I simply opened Illustrator CS2, grabbed the pencil tool and drawn. I then saved as AI. And i clearly see the drawn object within Illustrator.
    Was there something alse i should do in AI? what does this error message mean? What is a “usable vector path” and how is it different from what iam seeing in Illustrtor right now?
    Thank you
    PS: I am totally new to illustrator.
    Serge Hamad replied 20 years, 3 months ago 2 Members · 1 Reply
  • Serge Hamad
    May 14, 2006 at 5:24 am
    When saving your file, disable the “Use compression” check box.
    Salut.
    Serge
    “InvigoMany” now available here:
    https://www.nyc-visual.com
