Activity › Forums › Apple OS X › what hard drive add’n to G5?
  • what hard drive add’n to G5?
    Posted by Stu Aull on November 15, 2005 at 6:46 am
    Want to add a 2nd H drive to the G5. I know its an ATA serial – any brand to recommend or avoid? I’m assuming its pretty much plug and play install wise?
    Stu Aull
    2.0 Dual G5, FCP 4.5, Panther
    (soon to be FCP 5/Tiger but want to load the new OS on the new drive…)
    Stu Aull replied 20 years, 10 months ago 2 Members · 2 Replies
  • Francois Stark
    November 21, 2005 at 5:05 am
    Any SATA drive should work.
    To install, there are screws mounted in the G5 box for the purpose – these are metal screws with a extrended plastic screw head – they look like little mushrooms. After fitting them to the hard drive, it slides into the spare hard drive rack. Then you just fir the SATA power and data cables and away you go.
    Regards
    Francois
  • Stu Aull
    November 22, 2005 at 10:15 am
    sounds simple – as I HOPED it might (but you never should assume, so I thought I’d ask!)
    I plan to get a maxtor SATA 300G 16ms model
    thanks
    Francois!!
