Activity › Forums › Apple Final Cut Pro › What happens to FCP 7?
  • What happens to FCP 7?
    Posted by Don Walker on November 18, 2011 at 5:46 pm
    What happens to FCP 7 when FCP X trial is installed on the same partition? I know that originally FCP X displaced FCS 3. (out of the application folder?) I was running the demo on another partition, the trial ran out yesterday, but I need to fire it up one more time to make ProRes file for a client. (oops – poor planning!)
    don walker
    texarkana, texas
    John 3:16
    Oliver Peters replied 14 years, 10 months ago 5 Members · 4 Replies
  • Steve Connor
    November 18, 2011 at 7:11 pm
    Nothing happens, it functions as before. You can’t run both at the same time though.
    “My Name is Steve and I’m an FCPX user”
  • Jeremy Garchow
    November 18, 2011 at 7:22 pm
    I think they go in to a folder called “Final cut Studio Apps” or something like that.
    Jeremy
  • Andy Neil
    November 18, 2011 at 7:30 pm
    A folder called, “Final Cut Studio” is created in the applications folder. You can open them from there.
    However (and I realize its too late for you), this is NOT a best practices method for installing X on the same partition as 7. There is a knowledge base article on the apple website that details how best to do the installation if you want to run them both on the same partition.
    Installing X without following the “best practices” instructions can be fine, but you can also screw up linkage between the studio apps (ie: Send to Compressor, Send to Motion)
    Andy
    https://www.timesavertutorials.com
  • Oliver Peters
    November 18, 2011 at 9:48 pm
    [Andy Neil] “but you can also screw up linkage between the studio apps”
    So far no issue on my end with both on the same machine. The key, according to Apple, is to first open Motion 4 after the move. That’s before you do anything else. My guess is that this has something to do with correcting the links. If it opens fine, then test all the other FCS apps from the new folder. If these are all OK, then you should be fine.
    – Oliver
    Orlando, FL
    http://www.oliverpeters.com
