Activity Forums Adobe Premiere Pro What happens if I put my 24 fps footage into a 30 fps project
  • What happens if I put my 24 fps footage into a 30 fps project
    Posted by Louis Waters on April 27, 2018 at 1:19 pm
    What will happen if I put my 24 fps footage into a 30 fps project? Will anything bad happen? Is this wrong? I am transcoding the footage.
    Eliot Scarpetti replied 8 years, 4 months ago 4 Members · 4 Replies
  • David Roth weiss
    April 27, 2018 at 4:43 pm
    Dave,
    What??? Are you aware that there are times when you know what you’re talking about but no one else does… this is one of those occasions.
    David Roth Weiss
    Director/Editor/Colorist & Workflow Consultant
    David Weiss Productions
    Los Angeles
    David is a Creative COW contributing editor and a forum host of the Apple Final Cut Pro forum.
  • Shane Ross
    April 27, 2018 at 4:55 pm
    If your project is 59.94i (29.97 interlaced) then pulldown will be added to the 23.98 footage to make it into smooth 30fps (like what happens when TV shows shoot film at 24fps, but have it transferred to data files at 29.97). Premiere will add the pulldown.
    If the project/sequence is 30p…well, then 6 duplicate frames will happen in the footage and it will look slightly stuttery. Just a little. Nothing can be done about this…progressive to progressive frame rate conversions always just double up on a few frames.
    Shane
    Little Frog Post
  • Louis Waters
    April 27, 2018 at 5:33 pm
    [Shane Ross] “If your project is 59.94i (29.97 interlaced) then pulldown will be added to the 23.98 footage to make it into smooth 30fps (like what happens when TV shows shoot film at 24fps, but have it transferred to data files at 29.97). Premiere will add the pulldown.
    If the project/sequence is 30p…well, then 6 duplicate frames will happen in the footage and it will look slightly stuttery. Just a little. Nothing can be done about this…progressive to progressive frame rate conversions always just double up on a few frames.”
    Yes this makes the most sense thanks!
  • Eliot Scarpetti
    April 30, 2018 at 5:11 pm
    If on a single clip, use “Clip->Video Options->Time Interpolation->Optical Flow”
    If on an entire sequence, when you are exporting, at the bottom of export window, choose “Optical flow” as the Time interpolation method.
    It isn’t perfect, and if you’re a pixel peeper you might notice some odd artifacts here and there, but in the normal course of most applications no one will be able to tell. Hope this helps.
