Activity Forums Adobe Premiere Pro What happens if I never render video??
  • What happens if I never render video??
    Posted by Elliott Wright on February 5, 2010 at 6:31 am
    Trust me I’m not new to filming, editing, etc., though I’m still sorta “green” and I’ll admit that. Anyways this question has been nagging me for some time:
    What happens if I make a movie or even a DVD with Encore, yet I never render the video in Premiere? The reason I ask is because I used to think that the reason for rendering in your sequence was so that not only did the preview play back correctly, but so that the effect was applied PERIOD. But it seems that with some effects I can still play it back without having to render it which means the effect is getting applied. I know it doesn’t look as nice which is why I’d render it anyways for playback in editing. But if I never rendered it would the effect be applied correctly for the final film? Or would it just “not be applied”?
    Well there goes my first post! I’m glad to be a part of the community!
    Vince Becquiot replied 16 years, 7 months ago 7 Members · 8 Replies
  • 8 Replies
  • Mike Velte
    February 5, 2010 at 11:17 am
    Rendering “Preview files” is primarily for your viewing pleasure if your computer is not fast enough to give you a smooth preview, making editing difficult.
    Most computers today are fast enough to give a “real” preview without rendering especially for SD projects. Editing AVCHD with effects applied may only give a preview of a few frames per second and require rendering preview files in many cases.
  • Phocas Kroon
    February 5, 2010 at 11:03 pm
    You always need to render if you play the timeline back to tape.
    Phocas Kroon
  • Rob Lagerstrom
    February 8, 2010 at 12:27 pm
    When you export to Media encoder your un-rendered footage will be rendered during the encoding process.
  • Brian Louis
    February 8, 2010 at 7:35 pm
    [Phocas Kroon] “You always need to render if you play the timeline back to tape.”
    You mean if you export to tape, if my machine is fast enough I can do a external device preview, I can copy to tape without rendering
  • Jon Barrie
    February 8, 2010 at 9:44 pm
    Technically you r correct but there is no guarantee you’ll get full quality full frame rate and audio lag. Best to render if u want to even device out to tape deck to ensure quality. But then you might as well go to tape properly too. 😉
    Jon Barrie
    aJBprods
    http://www.jonbarrie.net
  • Brian Louis
    February 8, 2010 at 10:25 pm
    [Jon Barrie] “but there is no guarantee you’ll get full quality full frame rate and audio lag”
    That’s why you monitor it, and make sure settings are correct, I’ve haven’t had a problem with a SD or SDWS yet.
  • Jon Barrie
    February 9, 2010 at 2:41 am
    I was replying to the comment that if a machine was fast enough u don’t need to render to go out to tape…
    JB
    Jon Barrie
    aJBprods
  • Vince Becquiot
    February 9, 2010 at 4:08 pm
    Late to the party… I did notice in CS4, that an export through AME of rendered footage (not using rendered files) makes that export lightning fast, even at maximum quality, compared to a non rendered timeline.
    It seems that even the time it takes to render the timeline prior to the export makes the combined time much shorter than a non rendered export.
    No scientific study here, and I really haven’t looked into the reasons why that is…
    Vince Becquiot
    Kaptis Studios
    San Francisco – Bay Area
