Activity › Forums › Apple Final Cut Pro Legacy › What happened? My QT files are blank!
  • What happened? My QT files are blank!
    Posted by Gruniongal on June 14, 2006 at 7:46 pm
    Argggg. I downloaded and installed the latest RealPlayer Version 10.1.0 (412) and all of a sudden I notice that all my QuickTime movie files (.mov, etc) are blank and white and when I double click on them they open in….RealPlayer!
    I am cutting a documentary so I have dozens of QT files all over the computer and I would rather not spend the afternoon reprogramming them to “Open with” QuickTime.
    Has anyone else run into this problem?
    How can I UNDO this, get all my movie files back to QT, and make sure this does not happen again when I create a new QT movie file?
    Thank you all in advance!
    Gruniongal replied 20 years, 3 months ago 2 Members · 2 Replies
  • John Pale
    June 14, 2006 at 8:02 pm
    Control-Click on any of these Quicktimes in the Finder. Select Get Info in the contextual menu
    Go to the “open with” section of the Get Info Window.
    Change to Quicktime Player in the pull down menu.
    Beneath the pull down menu is a button to change all. Press it and all files of this type will open with Quicktime player.
  • Gruniongal
    June 15, 2006 at 3:24 am
    Thanks you very much for the info Jhon! This solved my problem.
