Activity Forums Adobe Premiere Pro What FPS should I use
  • What FPS should I use
    Posted by Art Thomas on August 25, 2012 at 9:30 pm
    Most of my on-location shoots are 1920HD at 60fps. I am creating outputs for video and audio. They will be used commercially on DVDs, websites, computers, IPADS, smart phones, and any other device.
    My question is:
    I do all my Premiere development work in 60fps/HD. What is the most effective output fps to use for all of these devices. Is there on;y one to use, or does each device require a different set up? Should I just stick to the 60fps/1920 for everything?
    Thank you for your help.
    Chris Tompkins replied 14 years ago 3 Members · 3 Replies
  • Ann Bens
    August 25, 2012 at 10:59 pm
    General rule: keep sequence settings the same as your source footage.
    Adobe Certified Expert Premiere Pro
    Adobe Community Professional
  • Art Thomas
    August 26, 2012 at 12:48 pm
    Thanks Ann. That is what I am doing. Just that many times I read a new article or on forums and “they” talk about “ideal” fps which seems to be different depending on who you talk to. After awhile it does get confusing. I will stick to what I am doing.
  • Chris Tompkins
    August 26, 2012 at 9:11 pm
    You can also choose the presets when encoding for the target intended.
    IOW
    Export using the mpeg2 DVD preset for DVD,s
    Export using the Vimeo preset for Online HD.
    1080i/60i is 60 interlaced fields, same as 30 (29.97) frames/second.
    Chris Tompkins
    Video Atlanta LLC
