Activity › Forums › Apple Final Cut Pro Legacy › What Format, What Codec?
  • What Format, What Codec?
    Posted by Rich Rubasch on March 10, 2008 at 12:26 am
    For Broadcast in small markets that don’t have HD I’m sure there are plenty of spots edited in SD uncompressed. But how about for projection in SD? Does anyone use DVCPro50? ProRes? DV25? HD downcoverted to SD?
    Just curious if projection automatically means it will be uncompressed if it’s going to be an SD projection. How about playback formats? DVCAM, DVD or file playback?
    Any of you event guys out there want to chime in?
    Rich Rubasch
    Tilt Media
    Christopher Wright replied 18 years, 6 months ago 5 Members · 4 Replies
  • Steve Eisen
    March 10, 2008 at 12:59 am
    Current projectors will detect automatically the signal it is being fed. Projectors have video (Composite, S-Video, Component and/or HDMI) and computer inputs.
    DV25, DV50, DVCPro HD ProRes are all compressed formats.
    To answer your question, no, the signal being projected will not be uncompressed.
    I’m guessing you concerned about quality. If your original video (DV or DVD) is good quality, any decent projector will display your video very good via video input. Obviously the component input will yield the highest quality.
    Steve Eisen
    Eisen Video Productions
    Board of Directors
    Chicago Final Cut Pro Users Group
  • Ernie Santella
    March 10, 2008 at 2:14 am
    Also to note, displays are notorious for adding artificial artifacts to the signal path. Especially SD programming. I’ve watched my projects on all kinds of Projectors (I have a $10K Marantz VP12S4 DLP that looks amazing) Remember, there are many different types of Projectors; LCD, LCoS, DLP. They all have their strengths and weaknesses. I’ve had to explain over and over to clients why it looks great when we edit, but crappy on their cheap home systems.
  • Arnie Schlissel
    March 10, 2008 at 4:20 am
    A lot of smaller festivals are projecting from mini-DV and from DVD. I’ve seen both projected on fairly large screens, and it can look good if it’s been done right.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Christopher Wright
    March 12, 2008 at 1:01 am
    I think that statement needs to be changed to “it can look good if it is SET-UP RIGHT.” Projecting a DVD is a crap shoot at any film festival unless your DVD is set up properly from bars and tone, hooked up component out of the projector, the projector is properly set up for either interlaced or progressive, it shows proper aspect ratio etc. etc. Few film festivals take the time, have experienced enough “projectionists” or care to to set up every film they show from DVDs at a festival. I saw one of my films played via DVD at 12 different festivals, and it looked (and sounded!) different in every single venue. I use the analogy of going into to a Best Buy, Circuit City etc. and seeing the wall of tvs, every one looking different than the next. Same old NeverTheSameColor (NTSC)twice dogma apply here. Set-up is critical and most film festivals don’t have the time or inclination to set up playback properly for HD, SD, Betacam, DVD or DV. I truly believe someone could make a fortune from a simple black box that could set audio and video levels automatically from color bars and tone fed into it, specifically designed for the film festival market…
    Dual 2.5 G5, IO, Kona LH, IO, Medea Raid, UL4D, NVidia 6800, 4Gig RAM
    Octocore 8 GB Ram, Radeon card, MBP, MXO
    Windows XP Adobe Studio CS3, Vegas 8.0, Lightwave 9.2, Sound Forge 9, Acid Pro 6, Continuum 5, Boris Red 4, Combustion 2008, Sapphire Effects
