Activity › Forums › Adobe Premiere Pro › What format is the Edit List export?
  • What format is the Edit List export?
    Posted by Mark Palmos on November 16, 2006 at 12:56 am
    Hello all,
    I have a half done project which must be finished on Discreet Edit for logistic reasons. I have tried exporting the EDL from PP and importing to Edit. Edit can take GVG, Sony, CMX, Convergence lists. The PP EDL export has almost no options, and it does not even say what format the EDL is in.
    Discreet Edit did not like the list and the operation failed. Is there some way of making this PP list standard CMX or GVG, Sony or anything useful?
    Mark.
    Mark Palmos replied 19 years, 10 months ago 4 Members · 4 Replies
  • Craig Howard
    November 16, 2006 at 2:26 am
    CMX3600 I seem to recall.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Premiere Pro 2.0
  • Troy Murison
    November 16, 2006 at 5:49 pm
    It is a CMX 3600 list but not to the strictest of CMX-ness. We have
    always had to open Premiere lists in a EDL utility like Pre-Reader or
    Phoenix List Manager and then resave them to work with most systems.
    The CMX controller that our colourists use will absolutely not open
    PPro lists.
    I really wish Adobe would get this kind of stuff right. It’s hard to
    call yourself ‘Pro’ anything with issues like this IMO. Like you said,
    just the shear lack of being able to control what you want/don’t want
    in a EDL is frustrating, let alone the fact that it’s bogus when you do
    export. I have never taken the time to open/look at a PPro EDL to see
    what exactly is wrong. If you knew, you could conceivably edit it in
    notepad rather than spend $$ on a utility. I don’t even know if/where
    you can get the two I mentioned anymore- they’re really old! EDL Max
    is one I’ve seen on the web but it’s really $$$$$. We don’t use PPro
    workflow much. I would use PPro more if this and a few other closely
    related items worked better/more reliably or even at all, so I just
    took a shot at one of those utilities being able to sort it out and
    that made the EDL work, so that’s as far as I got.
    -Troy Murison
    Seattle, WA
  • Baz Leffler
    November 16, 2006 at 11:41 pm
    Also Nuendo does not like a PPro EDL. I have fixed them in notepad but I can’t remember how I did it (but I do have notes somewhere on my system on what I did).
    But on a positive note, there is one program I know that likes the PPro EDL… yep… PPro reads them perfectly!!!!
    Baz
  • Mark Palmos
    November 16, 2006 at 11:52 pm
    Thanks guys,
    If you have any tips on what I can do to standardise the edl, that would be great. Otherwise I guess I will print the edl and recreate it manually, only about 50 edits anyway!
    tx
    mark.
