Activity › Forums › Apple Final Cut Pro Legacy › What first? Smoothcam or Color?
Posted by Cade Muhlig on January 4, 2008 at 8:11 pmShould I smoothcam filter, or send to color first?
Cade Muhlig replied 18 years, 8 months ago 3 Members · 3 Replies -
Kc Allen
January 6, 2008 at 9:29 pmI’d filter it first, color it last. The only catch is that you will probably have to export the clip as a movie after it’s smoothed out, then reimport the QT movie, and then color. My work doesn’t call for a lot of Apple Color work – normally the FCP color corrector is all I need – but when I have used Color I’ve had to use this little workaround quite a bit.
Maybe someone else has some more experience with it?
Who’s the more foolish? The fool, or the fool who follows?
Walter Biscardi
January 6, 2008 at 11:32 pmIf you apply the Smoothcam filter first, you will need to export the clip as a self-contained movie and edit it back into the timeline before you Send to Color.
If you apply the smoothcam filter after, then you can apply the effect to the clip after it has been color corrected.
Myself, I always apply all filters and effects BEFORE I send to Color so Color is the last application to touch the project before it lays back to tape. With filters in FCP, there can sometimes be unwanted changes to your video levels even if the filter has nothing to do with video levels. By making the final pass in Color, FCP does not touch the final timeline other than to master it to tape.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Cade Muhlig
January 7, 2008 at 12:41 amya, went with smoothcam first, but then i realized i didnt like most of it. Color at the very end is the path ill take from now on.
thanks!!!
