Activity Forums Apple Motion What export setting to use?
  • What export setting to use?
    Posted by Chrisyocum on February 5, 2006 at 9:32 pm
    Quick question about my workflow. I’ve exported several DV video clips that I want to composite into a montage in Motion. I exported my clips from FCP as Quicktime files using “Current Settings”. I then brought these clips into Motion and assembled them the way I wanted. Now, when I want to export my final montage comp from Motion for use in FCP, which is the best way to export it in order to ensure the highest quality? Do I export as a NTSC DV file, or should I use “Lossless Movie”?
    Mark Spencer replied 20 years, 7 months ago 2 Members · 1 Reply
  • Mark Spencer
    February 6, 2006 at 7:41 pm
    Don’t export anything, just bring the motion project file directly into FCP
    Mark Spencer
    Freelance Editor/Producer
    Apple-certified instructor, FCP, DVDSP and Motion
    Author, Motion Visual Quickstart Guide from Peachpit Press
    https://www.applemotion.net
