Activity › Forums › Adobe After Effects › What effects are these?
  • What effects are these?
    Posted by Alton Brown on July 14, 2016 at 4:56 am
    I need some help identifying the transitions and effect this guy uses. I would like to re-create my own version.
    https://www.youtube.com/watch?v=6qQyiIYkNI4
    Here are main transitions I need help identifying.
    Blur and then it snaps into focus and introduces a new scene @0:11 – 0:15
    Static waves and slight glitch effect @0:29 – 0:30
    Slow motion effect with the outline of a subject @1:17
    Video speeds up and transitions into the next scene @0:50 – 0:52 (I think this is the same as the first transition I spoke about @0:11)
    Lettering distortion @0:05 and distortion @1:25
    All help is appreciated! Thank you all in advance!
    John Cuevas replied 10 years, 2 months ago 2 Members · 3 Replies
  • John Cuevas
    July 14, 2016 at 1:48 pm
    First one uses a lot of the techniques of a Simulated Whip Pan. Check out some of these TUTORIALS for how to do it.
    Johnny Cuevas, Editor
    ThinkCK
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Cuevas
    July 14, 2016 at 8:41 pm
    I would mess with the free presets you get with AE listed under BadTV. There are some plugins you can also purchase that simplify the process, but they are just doing things that can be done natively in AE. A few can be found at AEScripts. Also check out the Twitch plugin, I’ve never used it, but I believe it can take care of almost all your distortion, bad tv, jumpy smeared effects.
    ThinkCK
  • John Cuevas
    July 14, 2016 at 8:46 pm
    You might be able to do that with the Echo effect.
    Try creating a fractal noise pattern in a precomp, dump it in the final comp. And then apply a displacement layer effect to your text and point it at the fractal noise pattern.
    ThinkCK
