Activity Forums Adobe Premiere Pro What does this icon mean?
  • What does this icon mean?
    Posted by Jeff Smith on June 30, 2014 at 3:21 pm
    It used to be just a sequence, like the one above. now it can only be opened in source window, not as a sequence. i’m on CS6. see image
    Jp Pelc replied 12 years, 2 months ago 2 Members · 3 Replies
  • Jp Pelc
    June 30, 2014 at 3:29 pm
    That’s a multicam sequence. If you hold command (ctrl on PC) while clicking, you should be able to open it in a sequence panel. If not, drag it into a sequence, then command click from there
  • Jeff Smith
    June 30, 2014 at 3:31 pm
    Ah, got it. thanks much……
    the transition from fcp has been painful.
  • Jp Pelc
    June 30, 2014 at 4:48 pm
    The transition is clunky in awkward. But I’m confident that once you get PPro down, you will fly through edits
