Activity Forums Adobe After Effects what does the loading-bar indicate?
  • what does the loading-bar indicate?
    Posted by Andi Wand on December 8, 2009 at 3:17 pm
    Hey there,
    what is AE actually doing, when the yellow loading-bar in the right-hand corner of the composite window is active?
    Is there any way to skip these calculations? For example, I have several objects which I want to rotate by 360°. So, when I set the keyframes there is actually nothing to be calculated, because whatever I rotate by 360° will look exactly the same as before. It really sucks that AE starts this calculation of whatsoever each time, after setting a keyframe.
    Please, is there any way to avoid this? I mean in general, not only in this case. Let me set all my keyframes first and then do your calculations (after clicking a button or so).
    Thanks a lot for, Andi
    Andi Wand replied 16 years, 9 months ago 31,410 Members · 1 Reply
  • Andi Wand
    December 8, 2009 at 4:21 pm
    Thanks a lot, I didn’t know that!!! Very handy.
    Andi
