Activity Forums Web Design (WordPress, Joomla, etc.) What does Flash 6 backwards compatible mean?
  • What does Flash 6 backwards compatible mean?
    Posted by Camogr3 on April 27, 2005 at 1:06 pm
    I need to render something I have built in Combustion to be “Flash 6 backwards compatible as far as a compression codec goes”…
    What exactly do you think this means? Can Flash 6 read an MPEG4 file? I don’t use Flash so I’m trying to figure out what I am suppost to give them.
    Any suggestions as to what “Flash 6 backwards compatible as far as a compression codec goes” means would be appreciated.
    Camogr
    Bret Williams replied 21 years, 4 months ago 2 Members · 1 Reply
  • Bret Williams
    April 28, 2005 at 4:48 am
    Sounds like you were supposed to create the project in Flash 6, not combustion. Anything other than that and they’re very confused.
