What does “deinterlace method” do?
Posted by Hugh Macdonald on July 31, 2009 at 1:32 amProject properties has three methods for deinterlacing. What does this really do? Where does it take effect; where does it matter?
Danny Hays replied 17 years, 1 month ago 3 Members · 3 Replies -
D. Eric franks
July 31, 2009 at 2:52 pmDeinterlacing can happen three ways:
* None: glue the two fields into a single frame (this is what happens by default when you upload to Vimeo/YouTube or whatever).
* Interpolate: toss away one of the fields, duplicate the other (at the cost of half of your precious HD resolution).
* Blend: combine the two fields into a sort of average.It does affect the look of the video, however, I have three cautions:
1. When you see interlacing on a single, still frame (esp. one with fast motion), it is NOT necessarily a sign of a problem, unless you are trying to pull a still frame out. When the video is shown in all of its full-motion glory, it might look fine.
2. In Vegas, toggle the Preview window to display “Best (Full)” and Shift+B to render a section of video to see the results. Lower quality previews usually won’t reveal what the deinterlacing is doing.
3. It is often recommended to use Interpolate for fast-moving objects and video (like sports) because this will produce a sharper image and use Blend for other types of productions (like a drama), because the video will be a little softer. I’m not going to disagree with that and say it’s wrong, but, honestly, the “right” method is the one that looks best to you.I have a video that actually shows all of this in action here: The Joy of Interlacing.
__________________
The difference between writing a book and being on television is the difference
between conceiving a child and having a baby made in a test tube.
— Normal Mailer
https://videopia.org -
Hugh Macdonald
August 1, 2009 at 5:23 amWhen does Vegas perform a deinterlace? All FX? Some FX? Only when changing from i to progressive?
Surely, if I am staying within SD there is no need to deinterlace? But perhaps when cropping or moving or converting from 1080i or PAL you would need to? But straight cuts — why deinterlace?
If I knew what actions caused a need to deinterlace, then I could choose which deinterlace method to use.
Danny Hays
August 2, 2009 at 8:41 amMost green screen, chromakeying works better with progressive footage. Also play oround with a golf swing or b-bal bat swing, Interpolate seems to work better with fast moving video, where blend seems to work better with fast moving footge. Danny
