Activity Forums Apple Final Cut Pro What do most of you do when it comes to archiving old projects?
  • What do most of you do when it comes to archiving old projects?
    Posted by Pete Johnson on April 23, 2014 at 5:58 am
    Since some projects can become very large what do most of you do when it comes to archiving old projects? Do you have a bunch of hard drives on the shelf or are you selective in what you archive and delete the rest? I’m just curious about everyone else’s process because I’m getting to the point where I am running out of space.
    Fabrizio D’agnano replied 12 years ago 9 Members · 10 Replies
  • 10 Replies
  • Jeff Kirkland
    April 23, 2014 at 7:08 am
    I have hard drives. Lots of them. I keep a copy of the original camera card files and a copy of the project library with render files, optimised media, etc deleted. Each drive is duplicated so there’s at least two copies of everything on separate drives.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Jeremy Garchow
    April 23, 2014 at 12:50 pm
    I keep everything as we really can’t afford not to.
    If a client calls and needs something back or updated, or whatever, we would be remiss to say, we didn’t save everything.
    We use LTO, but the process would be the same if using hard drives in that a set of tapes go on the shelf, and then a dupe set of tapes goes offsite.
    Jeremy
  • Bret Williams
    April 23, 2014 at 1:49 pm
    Current projects are on a Pegasus raid 5. Completed projects eventually migrate to a mirrored 3TB raid where I delete the camera media eventually but keep the ps, AE, music, sfx, etc. The camera media is backed up in multiple places on USB 3 drives. I try to keep ongoing backup drive(s) off site in case of break in or fire.
  • Bill Davis
    April 23, 2014 at 7:08 pm
    Media is stored in Sparse Disk Bundle Card Clones. These get mirrored onto 2 drives if the project is normal. 3 drives if the project is critical. Any large project (i.e. not audio or “move on still” based) is worked as Referenced Media linked to those card clones. So the FCP-X project files stay small and as such, I can “drag dup” the Libraries onto secondary and tertiary drives to clone the database as needed. I typically use just a secondary during the live life of the work, then make an additional backup to the tertiary drive after the project is complete.
    I’ve played around using the internal X “Camera Archive” system for making the sparse bundles – but I still find it more convenient to use Andreas Kiels’ SCDI utility to create them. Just so I don’t have to launch X in the field to make the clones.
    Since X can use ANY card clone group. And any mirrored copy of the library to re-launch the project, the key in my thinking is to have a standard as to the location/files where you do “live” work – and a strict path to where you store backups and how you ripple changes throughout the backup locations.
    The editors who have a constant flow of daily projects would need a much more sophisticated daily backup system. This works great for me.
    FWIW.
    Know someone who teaches video editing in elementary school, high school or college? Tell them to check out http://www.StartEditingNow.com – video editing curriculum complete with licensed practice content.
  • Pete Johnson
    April 25, 2014 at 1:16 am
    Thanks that’s really interesting. Just out of curiosity what level do you guys operate at, professional, semi-pro, ect.
  • Scott Witthaus
    April 25, 2014 at 10:29 am
    I budget in a USB3 drive or equivalent to each project. At the end of a project I copy and archive all the assets to that drive and hand it over to the client. For smaller jobs, multiples may be put on a single drive.
    I tell them I will keep the project active on my system for 3 or 6 months, depending on client, and then will delete. It’s their responsibility at that point. I can’t afford to be, or want to be, the archivist for my clients.
    Scott Witthaus
    Senior Editor/Post Production Supervisor
    1708 Inc./Editorial
    Professor, VCU Brandcenter
  • Mark Morache
    April 26, 2014 at 4:44 am
    My projects aren’t huge. I just did one that went over 100gb. I create a folder on the root of my working drive that contains the library, and folders with all my media, scripts, notes, important copies of emails, graphics, original layered photoshop files that I use to create merged graphics and final exports. This is backed up daily or more frequently depending on how much work I can afford to lose and re-do.
    Keeping all the media in external folders keeps the library size small.
    When I’m done and approved, I nuke my render files and I drag my entire folder with my library and media onto a backup drive (I use raw drives in a Voyager dock), which I keep a clone of. Repeat clients get their own hard drive for compiling projects.
    I also try to keep backups of every motion effect in my effects library. I tried re-opening an old project one time and couldn’t find a lower third I created, so I had to re-create it and replace the offline clips.
    Don’t live your life in a secondary storyline.
    Mark Morache
    FCPX/FCP7/Xpri/Avid
    Evening Magazine,Seattle, WA
    https://fcpx.wordpress.com
  • Bret Williams
    April 27, 2014 at 5:21 pm
    I have found that unless the client is a video producer, they have no clue where that drive is even months later. So for all inclusive clients we keep copies of everything. If the client is a producer we do just like you mention, but sometimes just the project and USED media since they already have their own copies of the camera footage.
  • Nick Papadopoulos
    April 28, 2014 at 8:11 am
    We have 3 drives:
    1. Archived projects
    2. Camera Media Archives
    3. Final Videos
    In drive 1 we put the project folder with the media and no exports. We use Final Cut Library Manager and trim the library down to the minimum.
    In drive 2 we ingest the media with the Create Archive option of FCPX in the beginning of the project (CF, SD cards etc…).
    In drive 3 we export 2 versions of each delivered clip. One Clean and one Dirty version with 8 Channels of audio. Clean is without graphics. Dirty is the finished clip with everything and the kitchen sink on it!!… Channels of audio are as follows (tip: we use roles for this)
    8 Channels:
    01 Full Mix – Stereo Left
    02 Full Mix – Stereo Right
    03 International Sound (Atmo) – Stereo Left
    04 International Sound (Atmo) – Stereo Right
    05 Music & Effects – Stereo Left
    06 Music & Effects – Stereo Right
    07 Voice Over – Mono
    08 Dialogue – Mono
    That way if the project is not opening with all plugins etc… a year from now, we still have a clean version to cut from with most audio available seperately. 8 Channels was chosen mostly for compatibility with XDCAM discs. One can use as many channels as they like….
  • Fabrizio D’agnano
    April 28, 2014 at 6:01 pm
    The multitrack file is a great idea. It’s nearly like having another copy of the project. I always exported one HD file with the total downmix and an aiff with the voiceover off for international versions, but dividing Music, Dialogues and so on is much better. thank you for the tip!
    Fabrizio D’Agnano
    Rome, Italy
    early 2008 MacPro, BM Intensity Pro, early 2008 iMac, 2011 MacBook Pro, FCP7, FCPX, OSX 10.8.3
