Activity Forums Adobe After Effects What do I need to make Previws faster
  • What do I need to make Previws faster
    Posted by Editdaddy on June 14, 2006 at 3:38 am
    I just got a HP xw4300 with a Pentium 4 (3.2 gig processor) and 1 GIG of ram. I would like to make my RAM previews faster, I think the simple answer would be to add 1 more GIG of RAM. My question is, do you think this would be a big help, or is there a better solution. I work with a lot of HD video.
    Editdaddy
    Steve Roberts replied 20 years, 3 months ago 4 Members · 3 Replies
  • Justin Productions
    June 14, 2006 at 6:44 am
    Well, from what I’ve heard, GridIron Nuclear Pro does a pretty decent job. Or you could increase your RAM by a value of 1.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • Al
    June 14, 2006 at 7:55 am
    i’d definately be working with 2 gig ram with HD. we’re also using GridIron Nuclear (not Pro) and it’s top notch
  • Steve Roberts
    June 14, 2006 at 2:01 pm
    Nucleo is good. I use it.
    Regarding RAM, I think the idea of more RAM making things faster is a holdover from the days where using less RAM might result in dog-slow writing to disk once all the RAM is used up. AE doesn’t work that way. When you run out of RAM, your RAM preview stops caching frames and plays back the frames it has.
    More RAM will, however, allow you to create longer RAM previews for a given image size and resolution, allow you to work with more apps open, and allow you to work with bigger source files.
    If you want things to speed up, you should get Nucleo, get a faster processor and/or use OpenGL in some situations.
