Activity Forums VEGAS Pro What codec for .flv files?
  • What codec for .flv files?
    Posted by Rob James on January 15, 2009 at 12:01 am
    Hey guys, I’d like to drop .flv files on to my timeline, what codec do I need? I’m pretty sure .flv is a flash format file, though not certain. Is it as simple as installing Flash? If so, is there a downloadable version? It’s for my offline PC, so I can’t install it in the normal manner, by visiting their site, and doing the auto install. I’m using Vegas 7.0e, so anyone with experience loading .flv files into that version of Vegas, I’d love to have your input. Thanks!
    Rob,
    https://www.robjames.net/
    Omer Aydin replied 15 years, 9 months ago 6 Members · 8 Replies
  • 8 Replies
  • John Rofrano
    January 15, 2009 at 12:41 am
    Vegas doesn’t support the editing of FLV files so you will have to use an external program like Super(c) to convert them into a format that Vegas can edit.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Omer Aydin
    January 15, 2009 at 1:08 pm
    You can open FLV files directly in Vegas by using a VFW (VideoForWindows) filter.
    https://sourceforge.net/projects/ffdshow-tryout/
    Install FFDSHOW and run “VFW configuration” (not “Video decoder configuration” which is for DirectShow decoding) from Start menu group, go to the Decoder tab, Codecs section, and make sure FLV1, VP6F are set to libavcodec.
    (FLV files with H26x codec are not guaranteed.)
  • Luke Walker
    November 29, 2009 at 9:56 pm
    I’ve followed the steps that you listed. Now what? I still can’t edit .flv in Sony Vegas. What am I missing? Thanks.
  • Rob James
    December 3, 2009 at 12:17 am
    What I’ve found, since posting this question originally is it’s best to convert your .flv to .avi using a converter program like Total Video Converter. https://www.freedownloadscenter.com/Multimedia_and_Graphics/Video_and_Animation_Tools/Total_Video_Converter.html
    Then it’s simply a matter of loading the .avi file on to your timeline, and editing at will. Hope this helps?
    Rob,
    Rob,
  • Russ Hurley
    September 2, 2010 at 6:32 pm
    just tried this – no dice with SVP 9.0 checked the codecs….SVP sat on the files for a while and looked like it was reading them, and then coughed up an error message – the same one i gt when i try to give it a MOV file…
    Sony Vegas London Users Group
  • Ben Hen
    December 20, 2010 at 11:57 pm
    I just used the Riva FLV Encoder, which is donor-ware and converts some standard file formats to FLV.
  • Omer Aydin
    December 21, 2010 at 8:30 am
    You are right. I just tried opening a flv with Vegas 6,7,8 and 9. It doesn’t work with 7 and above. Only Vegas 6 opens it. Sorry for the mislead. I thought 7 was also able to open it with ffdshow.
  • Omer Aydin
    December 21, 2010 at 8:48 am
    BTW, VLC Player can DirectStreamCopy a FLV file into a MP4 container without re-encoding. I tested it using a FLV file (h264) and Vegas 9 opened it.
