Activity › Forums › Sony Cameras › What Causes This?
What Causes This?
Posted by Alec Gitelman on November 9, 2010 at 7:36 pmHi,
this is a from a very quick pan, totally unusable shot, but I still wonder what’s making it look like that. I’m guessing it’s a combination of both rolling shutter and breaking the codec, but I’d like to know what to avoid if I were to be pushing the capabilities of the camera in a similar situation.
Can anyone point out what exactly is happening?
Thanks.
Bob Hayes replied 15 years, 10 months ago 5 Members · 10 Replies -
Craig Seeman
November 9, 2010 at 7:48 pmWhat frame rate, shutter speed?
A single frame can’t give us an idea how fast the pan is. Who’s going to see a single frame on a whip pan?
If it’s a slower pan than the above information might help.
That the image is blown out doesn’t help either. -
Alec Gitelman
November 9, 2010 at 7:57 pm -
Craig Seeman
November 9, 2010 at 8:04 pmThere are professional cinematographer guidelines on panning and camera movement at 24fps. Fast pans aren’t going to look good at that frame rate regardless of camera. This is why some people shoot sports at 60fps for example.
Shutter speed also impacts on motion blur and the more blur the likely more work for the codec with fast motion.
That your image is blown out in some areas and very dark in others just makes it that much more problematic.
If you’re shooting at 24fps pan slowly. Consider polarizer or some other method to knock down that contrast.
Alec Gitelman
November 9, 2010 at 8:16 pmI understand, in this case I was just swinging the camera around from shot to another.
I see the skew. I’m curious what causes those lines extending from the silhouettes appear.
Craig Seeman
November 9, 2010 at 8:18 pmProbably the radical change between dark to blown out on the codec with fast motion.
David C jones
November 9, 2010 at 8:39 pmIf I remember correctly, according to the ASC, [shooting @24fps] an object should take AT LEAST 8 seconds to pass from frame edge to frame edge during a pan.
Dave J
Noah Kadner
November 10, 2010 at 2:48 amExperience tells us it’s a lot easier to make an iffy looking frame than a nice looking one. Tripods or at least a shoulder mount and taking it easy with your pan speed will go a long way.
Noah
Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Canon 5D Mark II and 7D.
Bob Hayes
November 10, 2010 at 11:39 pmAlec
My guess is it is a LOG GOP artifact. One of the downsides of the EX1 is how it compresses the image and one of the results is a wavy vertical line when panning. Try shooting telephone poles from a driving car to really see the issue. I haven’t faced the problem but it occasionally rears its head. Recording onto an external drive eliminates the problem.
Bob Hayes
DP
Los Angeles -
Craig Seeman
November 10, 2010 at 11:55 pmBending lines is due to CMOS rolling shutter, not the codec.
Bob Hayes
November 13, 2010 at 6:33 pmOf course. I missed that in your earlier post. I have same problem but really exaggerated on my Contour camera.
Bob Hayes
DP
Los Angeles
