Activity › Forums › Adobe Premiere Pro › What caused this weird render? (pic inside)
  • What caused this weird render? (pic inside)
    Posted by Tl Westgate on August 22, 2008 at 1:36 pm
    I shot a short film for the 48 Hour Film Project on a Canon XH A1 camera in HD 30f mode. I edited in Premiere CS3 in full resolution and exported an uncompressed AVI. The entire video had this weird duplication of the rightmost 1/3 of the picture, like in this exported frame:
    What’s going on? We copied the entire project over to another machine and had the same result.
    — TL
    Oktay Ortakcioglu replied 18 years, 1 month ago 5 Members · 10 Replies
  • 10 Replies
  • Vince Becquiot
    August 22, 2008 at 3:32 pm
    Are you using an AJA or Decklink card ?
    Vince
  • Tl Westgate
    August 22, 2008 at 4:43 pm
    It was captured thru firewire.
    — TL
  • Ann Bens
    August 25, 2008 at 3:38 pm
    Have you checked your export settings, like the PAR.
  • Tl Westgate
    August 25, 2008 at 5:00 pm
    We exported 1920×1080.
    — TL
  • Vince Becquiot
    August 25, 2008 at 5:18 pm
    When I said AJA or Decklink I meant, are you using any of these cards codecs to export, or if not, what codec did you use ?
    I have seen this exact thing happen with an AJA card that didn’t support 30P native.
    Vince
  • Tl Westgate
    August 25, 2008 at 5:56 pm
    Like I said, it was captured via the firewire port directly from the camera into Premiere Pro using the HDV preset.
    — TL
  • Vince Becquiot
    August 25, 2008 at 6:29 pm
    Again, the concern here is the render/export, not the capture…
    Vince
  • Tl Westgate
    August 25, 2008 at 6:38 pm
    Oh, oops. I read that wrong. It was an uncompressed Microsoft AVI. The compressor was 10-bit YUV.
    — TL
  • Eric Addison
    August 26, 2008 at 9:07 pm
    Same thing is happening to me. If I export a 1920×1080 file, AVI or Quicktime, that happens. I’ve been meaning to post about it for a few days now. It’s really frustrating because I need to export out this project and I can’t.
    I’ve got an HDV project, shot 24F on a Canon XL-H1, captured through firewire – no capture card. It seems to be something in the PPro export that causes it.
    —Eric
  • Oktay Ortakcioglu
    August 28, 2008 at 11:41 pm
    I think it is a bug introduced by a CS3 auto update recently. I wish there was a way of rolling back the updates…. Anyone from Adobe around??
    Meanwhile, here is your workaround;
    When exporting movie (24 or 25f, out of Canon XH….), in settings, under “Keyframe and Rendering”, tick the box beside “Deinterlace video footage”…….
    Selecting “No Fields (Progressive Scan)” does not work…..BUG!!!
