Activity › Forums › Apple Final Cut Pro Legacy › What capture settings should I use for 1080i HDV from a Canon Xl H1 via Firewire?
  • Bill Kelly
    February 8, 2006 at 11:55 am
    Have you tried the HDV 1080i Easy Setup? I’ve brought in material from a Sony FX1 HDV camera and the easy setup has worked perfectly for both the capture and timeline. I had previously tried to do my own sequence & capture settings and didn’t have the greatest luck.
  • Stuart Simpson
    February 8, 2006 at 1:01 pm
    Sounds like you might have the DV downconvert option in the camera turned on. Check your camera is set to HDV over firewire in the settings.
    -Simmie
    2 G5 – Cinewave
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • Greg Mulvey
    February 8, 2006 at 6:52 pm
    I checked my settings and the AV>DV is set to OFF and HD DOWN-CONV is greyed out.
    When i play the tape back it says HDV60i in the view finder.
    When I try the HDV-1080i60 Easy Setup i get this error:
    Unable to loacte the following external devices:
    HDV (1440×1080) 30 fps
    When I go to capture I get this error…
    Unable to initizlize Capture Device and Device Control
    Any ideas?
    Greg Mulvey
    Designer:Animator
    https://www.gregmulvey.com
