Activity › Forums › Panasonic Cameras › What battery do I need for my HPX170 Remote Control?
  • What battery do I need for my HPX170 Remote Control?
    Posted by Christopher Targia on June 1, 2010 at 8:25 pm
    I had battery for my HPX170 remote control, and after a year of use it died. So I just replaced it, used the same type of battery needed, CR2025, I bought two energizer CR2025 batteries, so I would have a backup. I put the first one in and nothing… I double checked the type of battery and everything and I couldn’t figure out why it didn’t work. So I tried the other battery. This one worked without a problem. I figured I had a defective battery. Only problem is, this battery only lasted for two days. Does anyone else with this camera know what kind of battery I should be using for this remote?
    Before anyone makes a smart comment, I need the remote so I can run my teleprompter and the camera simultaneously without getting up.
    Thanks for any help.
    Michael Sacci replied 16 years, 3 months ago 2 Members · 3 Replies
  • Michael Sacci
    June 1, 2010 at 9:58 pm
    The batteries you purchased could be bad. Have you tested them? What is their voltage?
    If these batteries are good then maybe the remote is bad.
  • Christopher Targia
    June 2, 2010 at 12:55 pm
    how do i test them, the only thing i have that uses this type of battery is the remote. They are 3v batteries.
    MacPro Octo Core Intel Xenon 2.8Ghz 6GB 800MHz DDR2 Ram
    FCP 7.0
  • Michael Sacci
    June 2, 2010 at 6:34 pm
    a volt meter
