Activity Forums Apple Final Cut Pro Legacy what audio control sufaces work within fcp for Audio
  • what audio control sufaces work within fcp for Audio
    Posted by Lee on February 3, 2006 at 3:03 pm
    Hi
    I’ve ordered a Mackie MCU desk but there is none available till march so I’m told.
    I need something quite urgently.
    Is there any desks that can work within FCP and controlling audio?
    Does the Digidesign command 8 work? Know its a long shot!
    Paul
    Tom Volotta replied 20 years, 7 months ago 5 Members · 4 Replies
  • Jerry Hofmann
    February 3, 2006 at 3:52 pm
    None have been certified, however this one: https://www.bhphotovideo.com/bnh/controller/home?O=productlist&A=details&Q=&sku=288325&is=REG&addedTroughType=categoryNavigation is the one I keep hearing about working OK…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Godfrey Pye
    I have a Tascam FW-1082 and am quite happy with it as a control surface for both FCP5 and Soundtrck Pro.
    Godfrey Pye
    Mulholland Bays – in the Hollywood Hills
  • Chris Paul
    February 3, 2006 at 5:04 pm
    I have a Berhringer BCF2000. It is works well with FCP and is cheap ($200) but very annoying in that every time you get to a track with no audio the faders slam against the bottom of their track.
    Chris Paul
    POV
  • Tom Volotta
    February 4, 2006 at 2:27 am
    No, the Command 8 control surface will not work with FCP directly. It’s needs to see Pro Tools hardware.
    The M-Audio/Digidesign ProjectMix I/O recognizes the Mackie Protocol, so does work with FCP 5. The ProjectMix I/O also runs with Pro Tools M-Powered (sold separately), so if needed, you can work with either.
    https://www.m-audio.com/products/en_us/ProjectMixIO-main.html
    The Yamaha 01X which Jerry noted, also has the advantage over the M-Audio as being a standalone mixer and costs less.
    …Tom
