Activity Forums VEGAS Pro What Aspect Ratio for rendering a 16:9 project to DVDA?
  • What Aspect Ratio for rendering a 16:9 project to DVDA?
    Posted by Norman Willis on July 23, 2010 at 3:31 am
    First render of MPEG-2 for DVDA. My project settings are HD 1080-60i (1920 x 1080, 29.970 fps). Project length is 1:48:48;01.
    I want to burn DVD-R. I selected ‘Render As’, MPEG-2, DVD Architect NTSC Video Stream and then ‘Custom.’ Vegas gives me default values of 720 x 480, Output Type DVD, 4:3 display, Lower Field First, 9,500,000, 6,000,000, 192,000. Are those the right values? I tried Mark’s Bitrate Calculator, but it asked for some stuff I didn’t know.
    I want the best quality so I set the slider to 31, chose ‘Prioritize Quality over Speed’ and selected ‘Two Pass.’ If my project is 16:9 and I want to give preference to the newer 16:9 aspect ratio, do I also select 16:9 for the Aspect Ratio in rendering (I think so)? And if so, do I leave the same settings for the width and the height (720 x 480)? Or do I use something different/else? Thanks.
    Norman Willis
    http://www.nazareneisrael.org
    Scott Francis replied 16 years, 1 month ago 2 Members · 1 Reply
  • Scott Francis
    July 23, 2010 at 1:18 pm
    Yes, select 16:9. The footage will be letterboxed on older 4:3 screen..otherwise the footage will look odd. Another thing be sure that your footage is not 1440x1080i instead of 1920×1080…I made that mistake before…good luck!
    Scott Francis
    Mind’s Eye Audio/Video Productions
