Activity › Forums › Adobe After Effects › What are those 360 degree flat images called that you would use for enviro mapping?
  • What are those 360 degree flat images called that you would use for enviro mapping?
    Posted by Aza Allen on October 26, 2012 at 8:24 pm
    I’m trying to do an image search for those types of images, but I have no idea what they’re called…
    I basically want to map a 360 degree environment inside after effects to use outof the window of a car image to create the illusion of movement using Trapcode Horizon…
    Is there a better way to do this?
    My portfolio can be seen at http://www.ruesterprod.com
    My personal website is http://www.azaallen.com
    Matthew Keane replied 13 years, 11 months ago 3 Members · 2 Replies
  • John Cuevas
    October 26, 2012 at 8:31 pm
    Do a google search for 360 HDR photography , that returns some usable results(360 HDRI spherical will find some good ones too). I switched it to return large results. I wouldn’t use any of those photos for professional use, but if you need something to practice with…
    If you have CS6, you can use CC Environment, or the environment map also.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Matthew Keane
    October 27, 2012 at 1:56 pm
    You might also find some suitable images if you search for ‘equirectangular’ images.
    There are some good quality HDR images on this site:
    https://www.openfootage.net/
    Matthew Keane
    Freelancer based in Paris, France
    – Motion Graphics, Video Editing & Effects, Watchout Programming & Live Operation.
