Activity › Forums › Adobe After Effects › What are these video distortions (colorful echo trails?)
  • What are these video distortions (colorful echo trails?)
    Posted by J. Evan jordan on May 10, 2020 at 2:40 pm
    Hello,
    I’m hoping someone can help me with the colorful trails and colorful washouts in this:
    I’m hoping for just a few hints, hahah. How could i achieve a similar effect? Are the figures rotobrushed? I know to use the echo effect, but not how to use it on just an isolated color/area.
    Really appreciate any tips or advice!
    Evan
    Graham Quince replied 6 years, 4 months ago 3 Members · 4 Replies
  • Richard Garabedain
    May 10, 2020 at 2:58 pm
    are you sure you want ..”this”?.. echo effect and then probably duplicated the layer again..made it much brighter and then tinted it and used itself as a luma matte..im guessing since the edges are all over the place
  • J. Evan jordan
    May 10, 2020 at 3:10 pm
    Hiya, thanks!
    Yes, I’m looking for an abstract feel. Luma matte, thanks, gonna look into that.
  • J. Evan jordan
    May 10, 2020 at 4:15 pm
    I’m experimenting with the luma matte now.. Any idea how to isolate this effect only to certain areas of frame and not the whole thing?
    Thanks again..
  • Graham Quince
    May 17, 2020 at 5:08 pm
    When you say isolate the effect only part of the frame, have you tried using either masks or having the effect pre-comped and then using masks? If it doesn’t like working with masks you could always put the masks on a layer above and use alpha mattes.
    If you mean you only wanted working with the brightest part of the image, before the echo effect if you apply a levels effect you should be able to crank up the brightness of the bright spots and make everything else black
    http://www.YouTube.com/ShiveringCactus – Free FX for amateur films
    https://shiveringcactus.wordpress.com/ – FX blog
