Activity Forums Adobe Premiere Pro What are the standard numbers for the decibel levels I should be setting up my clips to?
  • What are the standard numbers for the decibel levels I should be setting up my clips to?
    Posted by Esther Casas on March 27, 2013 at 8:00 pm
    Hi everybody!
    I have been looking at premiere CS6 tutorials and I still have this question: when there are several audio clips in a composition (music, dialogues etc), in which number for the dB should I start setting up the levels?
    I am not sure where to start setting up and then adjusting. Don’t know what number is “industry standard” for the gain (set gain to and adjust gain by), also the peak amplitudes…
    Thank you!
    Esther.
    Brandon Reid replied 13 years, 5 months ago 2 Members · 1 Reply
  • Brandon Reid
    March 27, 2013 at 11:38 pm
    I generally normalize things to -6db. This makes it so I still have room for a loud noise or spike in the voice over, but I’m still getting good overall volume.
    So I’ll make sure all my audio clips are dancing around the -6db mark, one at a time. Then I’ll set keyframes and lower my music when someone is talking to around -15, although you could need more or less volume reduction depending on how compressed your music is.
    Once I’ve done all that, I’ll usually try and raise the master volume very slightly and get as close as I can to 0db without any distortion occurring.
    The key is having the entire piece at an even relative volume. If your video is being broadcasted on television. The master control room is usually equipped with a volume compresses/normalizer so it’s relatively the same as the rest of the broadcast.
