Activity › Forums › Apple Final Cut Pro Legacy › What are the networks accepting for HD?
Posted by Kenyon Blower on June 12, 2007 at 4:42 pmWhat HD formats are the networks (both Cable/Sat & broadcast) accepting for a HD format? I hear some are accepting XDcam & some are accepting HDV. Also are they accepting shows cut with the new Apple pro-res?
Kenyon Blower
Vide-Post / San Diego
Dual 2.5 G5
3 Gig Ram
Medea 2TB Fibre Raid
Medea 640 gig SCSI
FCP 5.1
KONA LHStuart Simpson replied 19 years, 3 months ago 7 Members · 6 Replies -
Shane Ross
June 12, 2007 at 5:20 pmWho’s accepting HDV? I’d be shocked if that was true…you can’t master to that format. Can’t lay back to it and have program start at 1:00;00;00. XDCAM? Haven’t heard that either. And the ProRes 422 codec is just that, a CODEC…not a tape format.
What networks are you talking about here? In my experience the networks that I work with only accept HDCAM, D5 and HDCAM SR. One was considering accepting DVCPRO HD, but have since excluded it.
Shane
Littlefrog Post
http://www.lfhd.net -
John Foley
June 12, 2007 at 6:00 pmWasn’t it recently announced here that FOX had purchased a ton of DVCPRO HD cameras? I think it was a bunch of HVX200’s? That must mean that at least they are utilizing DVCPRO HD?
Steve Braker
June 12, 2007 at 6:17 pmThat wouldn’t surprise me, but it has nothing to do with delivery formats. If you need to know what the deliverable is you need to ask your contact at a specific outlet. Or poke around their websites. BBC and PBS put out loads of info, I imagine that’s less common in the commercial world.
David Smith
June 13, 2007 at 1:00 amPerhaps Kenyon was asking about acquisition formats, not delivery?
Chris Borjis
June 13, 2007 at 4:44 amI know the OutDoor Channel accepts HDCAM (preferred) and will also take DVCPRO-HD.
It would be neat if cable companies and local stations would give specs for mpeg2 transport streams so we could deliver them electronically like DGS does.
Stuart Simpson
June 13, 2007 at 9:25 amThe BBC are currently using HDCAM only as a delivery format.
https://www.bbc.co.uk/guidelines/dq/pdf/tv/hd_summary_delivery_formats_v1_4.pdf
Acquisition is more relaxed, the BBC tend to take programes on a case by case basis. Good document here:
https://www.bbc.co.uk/guidelines/dq/pdf/tv/HDBookv01_02.pdf
-Simmie
2 G5 – Kona LH
3 G4s – Cinewave
1 xbox360, 1 PSP, 1 PS2 & a Gamecube
https://www.speak.co.uk
