Activity Forums Apple Final Cut Pro Legacy What are the Lowest Possible Export (Compression) Settings??
  • What are the Lowest Possible Export (Compression) Settings??
    Posted by Anthony Gerace on September 14, 2011 at 8:27 pm
    I want to export as quickly as possible. Video Quality is not an issue at the moment, I just want to export my full HD timeline into a quicktime file as quickly as possible so I can log the footage. WHat compression settings should I use to do so?
    Chris Tompkins replied 14 years, 11 months ago 2 Members · 1 Reply
  • Chris Tompkins
    September 14, 2011 at 8:43 pm
    Are you just viewing it on your comp?
    What do you mean by “log” the footage?
    File ~ Export – bam! Done in 2 sec.
    Export using “Current Settings”.
    Chris Tompkins
    Video Atlanta LLC
