Activity › Forums › Adobe After Effects › What are the effects used in this video?
  • What are the effects used in this video?
    Posted by Cindy Luk on April 24, 2013 at 1:10 am
    Specifically I’m talking about the sequence at 0:31. Is it simply a quick sequence of jump cuts or sth else? Pointers to other effects in the MV are much appreciated as well.
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    I/O- “Wasted My Time” from BRTHR on Vimeo.
    on a related front, any suggested resources for an AE newbie? I’m not looking at full tutorial, only simple pointers where I can research further.
    Thanks a bunch!
    Cindy Luk replied 13 years, 5 months ago 2 Members · 2 Replies
  • John Cuevas
    April 24, 2013 at 2:16 am
    It was just a bunch of cuts(some jumps) with a frame of black between them.
    If you want to download the video, copy the video url and head over to keepvid.com. Once you download it, you can bring it into AE and watch it frame by frame. Makes figuring things out a heck of a lot easier.
    Getting started with After Effects (CS4, CS5, CS5.5, & CS6)…the link to Andrew Kramer(Video CoPilot) is a pretty good getting started series.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
