Activity Forums Apple Final Cut Pro Legacy what are the default DV NTSC 48 KHz Anamorphic settings?
  • what are the default DV NTSC 48 KHz Anamorphic settings?
    Posted by Aaron Metchik on November 2, 2007 at 8:42 pm
    I accidentally edited (screwed up) the DV NTSC 48 KHz Anamorphic settings in my FCP capture presets tab. Can anyone tell me tue devault digitzer, compressor, quality, FPS and input settings under quicktime Video Settings. And are the width and height of the frame size still 720 by 480, just with the anamophic box checked? Hope someone can help. Thanks.
    P.S. Is there any kind of function to restore factory settings in presets if this kind of thing happens again?
    Aaron
    Nick Meyers replied 18 years, 10 months ago 3 Members · 2 Replies
  • Michael Sacci
    November 2, 2007 at 9:49 pm
    Take the default DV NTSC (locked) and duplicate it. Click the anamorphic box and there you go. All it is is a different pixel shape 1.2 vs .9 pixel count is the same 720×480.
  • Nick Meyers
    November 3, 2007 at 10:52 am
    “P.S. Is there any kind of function to restore factory settings in presets if this kind of thing happens again?”
    you can trash your preferences.
    that will re-set every thing to the defaults.
    if you have anything in your favorites folder,
    copy them all into a new “favorites” project.
    the favorites folder will be re-set to blank!
    read this:
    https://www.lafcpug.org/Tutorials/basic_trash_prefs5.html
    nick
