Activity › Forums › DVD Authoring › What are the best settings to use with Compressor? Is Compressor any good?
  • Alex Bond
    January 25, 2006 at 10:03 am
    Right…
    I’ve gone back to the source footage and checked that (I should have done this first but went and assumed it would be ok). The Video Compressor from Media 100 has done a bad job and the stepping is there on the Quicktime Export (I’m really sorry, I should have checked this earlier).
    Looks like I will have to do some work back on Media 100 and get the correct compression settings on that first and start again (armed with the tips you’ve given me which will be helpful I’m sure).
    Apologies and thanks for all your help
    Alex.
  • Turbojoe
    January 25, 2006 at 9:19 pm
    You should try exporting from Media 100 using the animation codec with millions of colors. This should give you the best qt mov to start from.
    Joe Atkins
    The Bingham Group
  • Alex Bond
    January 27, 2006 at 10:15 am
    Thanks, I’ll give that a go
    Alex
Page 2 of 2
