Activity › Forums › VEGAS Pro › What are the best Properties & Rendering settings – Sony Vegas Pro 10.0
Posted by Sean Tujaka on May 8, 2011 at 7:46 pmThe site I wanna upload to is Youtube.
Aleksey Tarasov replied 15 years, 3 months ago 4 Members · 10 Replies -
Sean Tujaka
May 8, 2011 at 8:16 pmI would like the best video & audio quality that Sony Vegas can offer.
John Rofrano
May 8, 2011 at 8:43 pmI would render as Sony AVC with the Internet 1280×720-30p template.
Of course this assumes that your video is HD. If it is not, then you need to give us more information about what you are doing.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
John Rofrano
May 9, 2011 at 12:21 am[Sean Tujaka] “I’m making music videos with movie clips & of course music.”
What resolution are the movie clips? (i.e., width?, height?, pixel aspect ratio?)
~jr
Sean Tujaka
May 10, 2011 at 8:08 pmFrame Width: 640
Frame Height: 360
Pixel Aspect Ratio: 1.0000 (Square -
John Rofrano
May 10, 2011 at 8:56 pm[Sean Tujaka] “Frame Width: 640
Frame Height: 360
Pixel Aspect Ratio: 1.0000 (Square”In that case use the “Internet 640×360-30p” template.
~jr
John Rofrano
May 11, 2011 at 2:50 am[Sean Tujaka] “Thank you, should I change anything in the custom?.”
Nothing really. It’s all set up for YouTube from Sony.
~jr
Thomas Roell
May 13, 2011 at 3:22 pmOne thing for youtubes is that the AVC renderer does 29.970fps. I sometimes get material with real 30fps. In that case the Sony AVC codec is not usable as it crashes for me when I try to match the frame rate. The MainConcept codec does allow to do that.
Why does it make a difference ? If you have real 30fps source material and convert that to 29.970fps then either you start interpolating frames, or if you disable that, you get some stuttering (barely visible, but still). I found this especially unpleasant if the source material contained considerable movement …
– Thomas
Aleksey Tarasov
May 13, 2011 at 4:58 pmYou can slow down 30 fps clip to 29.97 fps (set playback rate to 0.999)
