Activity Forums Adobe Premiere Pro What are the best (Mp4) Media Encoder settings for playing HD through large monitors and Projection TV?
  • What are the best (Mp4) Media Encoder settings for playing HD through large monitors and Projection TV?
    Posted by Charles Mckee on September 21, 2014 at 8:06 pm
    We produce video courses that are viewed in desktop arrangements, (15”-30”) or on large LED monitors (30”+ to 75”) or projected (10’ to 30’+)…. They have to be kept at high quality because of the text and graphic info. They are usually played directly off the hard drive or a USB-3 flash stick (never streamed).
    Our masters that we export to Adobe Media Player are 1920X1280 or 1280X720 Cineform 10bit uncompressed files or exported directly off the Premiere CC 2014 timeline….. Our current setting for 1920X1080p is as below. Other than the high bit rate (too keep the picture from looking fuzzy or getting pixel blocking) is this the best setting layout? Can anyone recommend any improvements or suggestions? Please help! Thank you very much.
    H.264
    1920X1280
    29.97p (Square Pixels)
    NTSC
    Profile= Main
    Level 4.1
    Rendered at Maximum Depth (Checked)
    VBR, 2-Pass
    Target Bit rate= 16Mbits
    Maximum Bit rate= 16Mbits
    Key Frame Distance= 72
    Use Maximum Render Quality (Checked)
    Audio= AAC, 4800Hz High Quality
    cm
    Charles Mckee replied 11 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
