Activity Forums Adobe Media Encoder What are the best (Mp4) Media Encoder settings for playing HD through large monitors and Projection TV?
  • What are the best (Mp4) Media Encoder settings for playing HD through large monitors and Projection TV?
    Posted by Charles Mckee on September 22, 2014 at 3:56 pm
    We produce video courses that are viewed in desktop arrangements, (15”-30”) or on large LED monitors (30”+ to 75”) or projected (10’ to 30’+)…. They have to be kept at high quality because of the text and graphic info. They are usually played directly off the hard drive or a USB-3 flash stick (never streamed).
    Our masters that we export to Adobe Media Player are 1920X1280 or 1280X720 Cineform 10bit uncompressed files or exported directly off the Premiere CC 2014 timeline….. Our current setting for 1920X1080p is as below. Other than the high bit rate (too keep the picture from looking fuzzy or getting pixel blocking) is this the best setting layout? Can anyone recommend any improvements or suggestions? Please help! Thank you very much.
    H.264
    1920X1280
    29.97p (Square Pixels)
    NTSC
    Profile= Main
    Level 4.1
    Rendered at Maximum Depth (Checked)
    VBR, 2-Pass
    Target Bit rate= 16Mbits
    Maximum Bit rate= 16Mbits
    Key Frame Distance= 72
    Use Maximum Render Quality (Checked)
    Audio= AAC, 4800Hz High Quality
    cm
    Ivan Myles replied 11 years, 11 months ago 3 Members · 2 Replies
  • Ryan Holmes
    September 23, 2014 at 8:38 pm
    If final file size isn’t a big deal (since you’re playing from a hard drive or thumb drive) then get rid of 2-pass VBR (Variable bit rate). Do a CBR and set the data rate at 16mpbs.
    You can also shorten you keyframe distance down to your frame rate (or even half your frame rate). Typically I do keyframe distance at the frame rate – 24, 30, 60, etc. That way every second I’m guaranteed an I-frame as it encodes.
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Ivan Myles
    September 24, 2014 at 4:21 am
    In the export panel under the Multiplexer tab check that stream compatibility is set to Standard. You might also consider increasing the target bitrate to 20-24 Mbps or higher; the 1280p equivalent to Blu-ray quality would be about 40-42 Mbps.
