What Are Recommended Workflow/Settings HDV (Sony FX1) to DVD – PP2 and Encore2
Hi.
I’m doing HDV test with my FX1. I’m doing a long shot of trees zoomed tight and slowly widen out (over 15 seconds). Playback of mpeg clip in PP2 looks fine, smooth, no artifacts.However – playback of clips after export to mpeg2-DVD or uncompressed AVI file produces a wavy, shimmery, wierd artifact that’s most notable along a vertical line in center of frame.
Encore2 created DVDs using the mpeg2-DVD or uncompressed files “faithfully” reproduced the wavy, shimmery artifacts.
My PP2 setting for capture were Adobe HDV , HDV1080i 30 (Sony60i).
The problem seems to occur when converting the original mpeg file created by the original capture.
One other note – a 780 by 400 mov clip created by exported using Quicktime Animation codec plays back with no problem. However, this won’t import to Encore. Encore says it needs 720×480 or 720×486 or 704×480. I did create a mov 720×480 but playback of this also showed the wavy, shimmery problem.
I did burn a DVD from PP2 using the 780×400 mov clip and it came out fine.
Bottom line – what is the preferred workflow and project capture settings in PP2 and what settings to use in the encode process to export for Encnore?
Many thanks for any insights. alan
Alan Julich
