Activity Forums Apple Final Cut Pro Legacy What am I doing wrong with Transition Keyframing
  • What am I doing wrong with Transition Keyframing
    Posted by Naiche Lujan on February 12, 2009 at 11:07 pm
    I am just doing some basic cutting between different images and I have applied some keyframed motion to the images ala Ken Burns, but after adding cross-fading between the images, you can see a few frames of no motion, before the motion begins.
    In other words because the transition adds some frames before the place I added a keyframe, you can see the next image sitting still for a few frames, then picking up the motion where I put the keyframe.
    I thought FCP automatically adjusted the keyframing for you when you added the transition so that it appears smooth. I’m sure it’s something very basic that I’m missing.
    Naiche Lujan replied 17 years, 7 months ago 3 Members · 4 Replies
  • Walter Biscardi
    February 12, 2009 at 11:09 pm
    Your keyframes most likely start after the transition begins and before the transition ends.
    So the dissolve starts, your image is sitting still, then the first keyframe tells the image to start moving. You need to back that keyframe up so it starts before the dissolve.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Naiche Lujan
    February 12, 2009 at 11:17 pm
    You are totally right, that is exactly what is happening.
    However, if you can believe it, I have no idea how to move a keyframe. Also, I feel like I’ve seen FCP automate this task, sort of like snapping, so you don’t have to update manually if you add or remove transitions.
    Thanks for the reply.
  • Kai Cheong
    February 13, 2009 at 3:33 pm
    Unfortunately, I don’t seem to know the auto-snapping of keyframes [am keeping my ears pricked for a possible solution since it gets tiring having to readjust your keyframes whenever you introduce a transition effect].
    But instead of manually dragging my keyframes to the updated start and end point [which can be tedious and inaccurate], when I’m in the motion tab, I use ‘Option-I’ and ‘Option-O’ to get to the in and out points of the clip, and insert a keyframe on both ends. They would keep the values of the existing in and out keyframes. Then, I’ll go and delete the old keyframes.
    Kai
    FCP Editor / Producer with Intuitive Films
    Now ‘LIVE’! Check Out The Intuitive Films Blog @ https://intuitive-films.blogspot.com
    At Intuitive Films, We Create: TV Commercials, Documentaries, Corporate Videos and Feature Films
    Visit us @ https://www.intuitivefilms.com
    MacBook Pro 2.4GHz | 4GB RAM | FCP 5.1.4 | Mac OS X 10.5.2
  • Naiche Lujan
    February 16, 2009 at 6:16 pm
    Thanks Kai, I try that out.
