Activity Forums Adobe After Effects What 3d application intergrates best with AE?
  • What 3d application intergrates best with AE?
    Posted by Ivy Calhoun on December 3, 2008 at 6:40 pm
    Well like I said in the subject, which 3d app works best with AE?? I’ve been under the impression that it’s cinema 4d, but I’d love to get other people’s opinions/the pros and cons of using cinema 4d vs something like maya or 3ds max. Any opinions??
    Rigeers Kasneci replied 17 years, 9 months ago 3 Members · 2 Replies
  • Sam Young
    December 3, 2008 at 9:52 pm
    cinema 4d …. Cinema 4d …. CINEMA 4D……
    like all other 3d apps, c4d lets you model objects, animate cameras and lights, and render out an image sequence.
    from c4d, you can export an after effects project file. in that, all of your c4d camera and light moves are translated to AE cameras and lights that move in the same way. this would allow you to add 3d layers in AE that would move in a way correspondent to c4d’s objects moved in relation to the c4d camera.
    plus, c4d is cheaper than maya and way easier to learn than maya.
    if you want to use a 3d app to make motion graphics, c4d comes with a module called mograph that allows for making complex clones of objects that can be animated/arranged along splines, and can animate in response to audio.
  • Rigeers Kasneci
    December 3, 2008 at 10:45 pm
    How can I Import 3D Models Created In Other 3D Programs to zaxwerks pro. It says it is duable but I do not know how. Can someone help me out. Thnx in advance
    P.S.
    I am a rookie 🙂
