Activity › Forums › Apple Final Cut Pro Legacy › Western Digital External Hard Drive
Posted by Rachel Miller on October 21, 2010 at 3:20 pmHi Guys,
Recently I purchased a 500 GB WD drive. I did not know that it had a speed of 5600 RPM and this would cause constant drop frames when editing. The salesman at Best Buy didn’t inform me about this. I have been editing using a G tech 7200 rpm drive that works wonderfully but I won’t have access to it anymore. Can I keep using mines or I’m out of luck and need to purchase a new one?
Rachel
Kenny Powerass replied 15 years, 11 months ago 4 Members · 6 Replies -
Jim Glickert
October 21, 2010 at 3:43 pmI think you’d be better off buying a new hard drive. The WD is only going to give you headaches. Get a 7200 rpm (or higher) drive with a higher capacity (1 or 2 TB), and with a fast connection (like FireWire or eSATA). Use your WD as a backup drive. In video editing, it seems like you can never have enough storage.
Jim
Rachel Miller
October 21, 2010 at 3:48 pmThanks for the reply! Is it possible though for me to be able to edit using this drive for a 7 minute trailer?
David Roth weiss
October 21, 2010 at 5:06 pmWhat is the connection you’re using on that drive Rachel? Firewire 400, 800, or USB?
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
http://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
Colorist – UP IN THE AIR (electronic press kit) – nominated for six academy awards
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
David Roth weiss
October 21, 2010 at 6:48 pm[Rachel Miller] “USB”
There’s the problem, it’s not the drive speed. USB does not deliver the necessary sustained throughput for video editing. There’s a reason they are cheaper than firewire drives…
David Roth Weiss
Los Angeles
Kenny Powerass
October 21, 2010 at 11:08 pmI’ve been working on a project with another editor for a while. He filled two identical media drives and shipped one to me. He used WD MyPassport SE portable USB drives. When it arrived I told him it would never work and we’d have to upgrade to firewire. He said he’d done it before and it was fine. I agreed to go with it until the edits were too complicated for the USB to manage.
In months of working this way, with multi-layered HDV video and audio we’ve never had so much as a hiccup. I’m pleasantly surprised.
I say test out your drive and see if it can handle what you’re throwing at it first, but be ready to upgrade if it doesn’t.
