Activity › Forums › Adobe After Effects › ‘weld’ with sparks effect
Posted by Jim Bachalo on September 15, 2011 at 3:20 pmHi
Can anyone tell me if the ‘weld with sparks’ effect
https://www.zacuto.com/bts-webisode-1exactly 30 seconds in
is possible to do natively with AE, or do I need to purchase a plugin ie Particular?
Local is the new global
Walter Soyka replied 15 years ago 5 Members · 5 Replies -
Ben G unguren
September 15, 2011 at 3:32 pmAE’s “CC Particle World” plugin should give you what you’re looking for. Here are a couple tutorials that should get you started:
https://www.videocopilot.net/tutorials/3d_sparks_title/
https://effectsportal.net/index.php/2-minute-tutorial-how-to-make-sparks-in-ae/Ben Unguren
Motion Graphics & Editing
http://www.mostlydocumentary.comSome contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Tudor “ted” jelescu
September 15, 2011 at 4:38 pmI’ve used CC Particle World to do thhis kind of effect and it worked great for me.
Tudor “Ted” Jelescu
Senior VFX Artist -
Jim Bachalo
September 15, 2011 at 5:09 pmThanks…will give it a try…will eventually get Particular but if I can save $400 for just this effect…
Raine Vivian
September 15, 2011 at 7:44 pmCC partical world should work fine. He the blend mode to add, and duplicate the layer a few times to add intensity.
-Raine Vivian
http://www.rainevivian.net
http://www.seaboundesign.com -
Walter Soyka
September 15, 2011 at 10:30 pm[jim bachalo] “will eventually get Particular but if I can save $400 for just this effect…”
As the others said, CC Particle World will do this effect well.
That said, Particular is incredibly flexible, and you can use it for all sorts of effects that you might not think of at first. It’s a great buy, and once you have it, you will find all sorts of uses for it. For example, see this recent thread where Marc De Coster is building an animated dandelion with Particular [link].
Walter Soyka
