Activity Forums Adobe After Effects Weird yellowish tint when importing illustrator files to Afx?
  • Weird yellowish tint when importing illustrator files to Afx?
    Posted by Cade Weisberg on April 18, 2017 at 3:08 pm
    Ok so I just edited this 3 illustrator files and when I import them to After Effects, 2 of them changed colors. Like there’s some sort of yellow tint. Which is odd because the third file doesn’t have one. As far as I’m concern all the three files have the same settings in Illustrator.
    I added the files in case you guys wanna check it out.
    11272_illustratorobjects.rar.zip
    Scenery 1 and 2 have this problem while the 3 is fine.
    Any ideas? Thanks.
    Roei Tzoref replied 9 years, 4 months ago 2 Members · 1 Reply
  • Roei Tzoref
    April 18, 2017 at 6:04 pm
    you should work in RGB and not CMYK if you are working for After Effects. change it under file->document color mode->RGB.
    Roei Tzoref
    After Effects Artist & Instructor
    ♫ Ae Blues Tutorials
