Activity › Forums › Compression Techniques › Weird video quality issue
  • Weird video quality issue
    Posted by Persta on February 7, 2006 at 9:54 am
    Hello!
    Recently I did a fresh install on my system (XP Pro SP2) and since then I’ve been having this problem.
    When I render stuff from After Effects 6.5 as image sequence,uncompressed avi or QT Animation everything is fine. If I try to encode these files to any other format, or render to a compressed file format from AE, I get this strange degradation of quality that is most prominent on strong colors. It looks a little bit like slight interlacing or loss of resolution. Red is the most affected color but it shows also slightly on blues and greens. However whites, yellows and subdued colors look fine.
    This problem is not related to After Effects alone. It happens also when I’m encoding with TmpgEnc and QT Pro. It also affects all codecs.
    Has anyone seen something like this before? I will upload screenshots to photobucket or similar so you can see it. I will post the link to the images as soon as I have them uploaded.
    Thank you!
    Pertti Jaasaari
    Persta replied 20 years, 7 months ago 2 Members · 3 Replies
  • Persta
    February 7, 2006 at 10:19 am
  • Charles Simonson
    February 10, 2006 at 6:16 am
    Sounds like a color conversion issue. You are probably editing RGB images in AE, and when you go to compress, the color spaces for the codecs are generally YUV. And the conversion the apps and encoders are doing is not good it appears. On the mac, Compression Master is fantastic at this sort of stuff. On the PC, VirtualDub or AVISynth with the right filters is a good route to go as well.
  • Persta
    February 10, 2006 at 8:59 am
    Yes, this seems to be the case. It seems like it is a Winows problem because every piece of software I am using is suffering from this, and I am absolutely sure I did not have this problem prior to re-installing my OS.
    My system:
    P4 2.0 Ghz
    Intel D850MV
    1GB RDRAM
    Canopus Dvstorm2
    Matrox G550
    Xp Pro Sp2
    DirectX 9.0c
    Let’s see if re-installing everything once more does the trick.
    Persta
