Activity Forums Apple Final Cut Pro Legacy Weird Unwanted Change in Aspect Ratio/Size
  • Weird Unwanted Change in Aspect Ratio/Size
    Posted by Ralph Chaney on November 29, 2012 at 9:38 pm
    Aspect ratio changes -without my input- when played in Quicktime…!?
    Here’s the deal:
    Working with a 1920×1080 DVCPROHD timeline.
    1. Export, after rendering. (No conversion of any kind)
    2. Shows as 1920×1080 in Finder, and plays as 1920×1080 in Finder (hit space bar)
    3. Plays as 1920×1080 in Final Cut 7.0.3
    4. BUT – when I open and play in Quicktime it plays as 1280×1080
    5. AND – If I send to compressor to convert to “50% of source”, it comes out squeezed to 640×540, same ratio as 1280×1080.
    So:
    Final Cut 7 and the Finder treat it as 1920×1089
    Quicktime and Compressor treat it as 1280×1080
    somebody HELP me! (…voice of Jim Carey in The Mask)
    -> Ralph
    Ralph Chaney replied 13 years, 9 months ago 1 Member · 1 Reply
  • Ralph Chaney
    November 29, 2012 at 11:11 pm
    Thanks.
    I usually work in ProRes, so thanks for the DVCPROHD 1280 info.
    I used Compressor and got VERY STRANGE – inconsistent results!
    (at least inconsistent with my understanding of how Apple’s video products really work)
    I sent a DVCPROHD test to Compressor from the timeline, and forced it’s setting to 1920×1080.
    In Final Cut: It STILL shows up as 1280×1080, as per bin info.
    In Quicktime: It shows up as 1920×1080, as per Info window.
    Remember – a straight export from the timeline yields a Quicktime-interpreted file of 1280×1080.
    **Perhaps Compressor adds some kind of cueing code that tells Quicktime to see it at 1920×1080?
    Do you know anything about this?
    (The TV station is requesting it in DVCHDProHD 1920×1080, so I’ll use a Compressor 1920×1080 version of the show since Quicktime is interpreting it that way and they want a Quicktime file.)
    Today’s Lesson:
    Learn more about DVCHDPro -and/or- Always use ProRes.
    -R.
    -> Ralph
