Activity Forums Adobe After Effects Weird ‘tv static’ glitch out of encoder
  • Weird ‘tv static’ glitch out of encoder
    Posted by Dylan Mercer on January 28, 2016 at 7:17 am
    Hi, I need some ideas.
    Everything I put into Media encoder keeps coming out with this angled lines accross half the frames.
    I am working at quite a high resolution (1800×1717) but my 18 second animation is not very intensive.
    when I send my renders to the Media Encoder Queue, I use H.264, and use the ‘match source, high bitrate’ preset.
    all my renders from this and other after effects projects returns the same glitchy output.
    here is a still from one of the renders.
    -heres a link in case the embeded image doesn’t work:
    Chris Evans replied 10 years, 7 months ago 2 Members · 5 Replies
  • Chris Evans
    January 28, 2016 at 3:25 pm
    Did you try rendering out from AE as a high quality codec, then transcoding to h.264 in encoder?
  • Dylan Mercer
    January 28, 2016 at 10:19 pm
    [Dave LaRonde] “H.264 only works with standardized dimensions.”
    Thanks for your response Dave. That could be a part of it, but I ran the same render through encoder on my workmates’ PC (I run a Macbook Pro) And it worked fine with those dimensions
  • Dylan Mercer
    January 28, 2016 at 10:20 pm
    [Chris Evans] “Did you try rendering out from AE as a high quality codec, then transcoding to h.264 in encoder?”
    Yep I tried that. It still returned the exact same glitch!
  • Dylan Mercer
    January 28, 2016 at 10:39 pm
    -Actually this DID work, sorry. the glitch is only hapenning for renders sent from Ae CC 2015 to Media Encoder CC 2015
  • Chris Evans
    January 29, 2016 at 4:08 pm
    Tis an odd glitch and I don’t think it should happen, but rendering high quality from AE is the general workflow most people work in anyway.
