Activity Forums Apple Final Cut Pro Legacy weird time code offset
  • weird time code offset
    Posted by Redžinald Šimek on April 18, 2008 at 12:39 pm
    we shoot feature on sony F23@25fps, and guys in the post facility transfer rushes on the DVCAM for offline edit.
    Time code is also burned on the image.
    When i try to capture offline on the FCP via Firewire i got weird time code offset of 4 frames, on each tape, always the same. Time code burned on the image correspond to the time code on the tape, but when i capture it, time code on the file is 4 frames late. I try to capture from the other device, but i got same result,
    I check all settings but everything is as usual.
    any suggestions
    thanks
    Redžinald Šimek replied 18 years, 5 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    April 18, 2008 at 8:06 pm
    Capture via rs422 or set your frame offset for 4 frames in a duplicated dv device control prefs.
    Jeremy
  • Redžinald Šimek
    April 23, 2008 at 1:32 pm
    i cannot capture via 422, and i try to change frame offset but without any result.
    anything else to try?
  • Jeremy Garchow
    April 23, 2008 at 1:40 pm
    Firewire is notoriously inaccurate.
    Where did you set the frame offset?
    Jeremy
  • Redžinald Šimek
    April 23, 2008 at 1:49 pm
    i made copy of firewire pal basic device control preset and i change inside of it.
