Activity Forums Adobe After Effects Weird things happening in AE – ram preview – audio preview
  • Weird things happening in AE – ram preview – audio preview
    Posted by Hope Holmesby on December 7, 2014 at 1:30 am
    Hi, thanks for reading.
    some keyboard commands are not working
    When using 0 on numeric keypad for ram preview nothing happens. Also when using ‘.’ for audio preview – nothing.
    Was working a few days ago.
    instead, the arrow tools get stuck in drag mode. Does work from the Preview palette if clicking the buttons: Ram and Play
    the space bar does allow playing.
    tried shutting down, restarting, pram zap, making anew project.
    still does same thing
    any ideas?
    Thanks again for any idear…..
    Warmly,
    Hope
    __________________________________________________
    Life is here to enjoy.
    iMac 3.5 GHz Intel Core i7, 2TB;
    Mac OS 10.9,
    16 GB RAM;
    2 La Cie external HDs 1 TB each;
    After Effects CS5.5;
    Sound Track Pro 3.0.1;
    Final Cut Pro 7.0.3;
    Compressor 3.5.3
    Hope Holmesby replied 11 years, 9 months ago 2 Members · 2 Replies
  • Brian Charles
    December 7, 2014 at 2:24 am
    Have you tried resetting After Effects default preferences?
    Since you’re on a Mac here’s the procedure:
    Launch After Effects while holding down Option + Command + Shift
    You should be presented with a dialog asking whether you want to reset the preferences. Click Yes… and see whether this resolves the issue.
  • Hope Holmesby
    December 7, 2014 at 3:01 am
    Hi
    thanks for the answer….i Tried that…didnt work
    turns out I had turned on Mouse Keys in Macs Accessibility area: Mouse and Trackpad.
    Maybe there is a keyboard shortcut that turn it on by accident.
    oh brother.
    thank you Brian for your input.
    inspired me to look further.
    Warmly,
    Hope
    Mac OS 10.9,
    16 GB RAM;
    Compressor 3.5.3
