Activity Forums Apple Final Cut Pro Legacy weird text and graphic shifts when editing…
  • weird text and graphic shifts when editing…
    Posted by Beenice on February 2, 2007 at 4:04 pm
    So I have a .psd graphic as a lower third with text from FCP over that. When the scrubber is still the graphic and text is exactly where I placed it. When I play the time line (with everything completely rendered) The two shift up slightly. I exported a test QT to see if it was just a bugging timeline thing but the test QT is the same. I’ve dumped preferences, restarted in Safe Mode and repaired permissions, etc etc.
    Anyone know what’s going on?
    -B
    Kate Marquis replied 19 years, 7 months ago 4 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    February 2, 2007 at 4:20 pm
    Yes. When FCP is paused, it shows you a high quality image, when playing back it lowers the resolution to give you smooth playback.
    Shane’s Stock Answer #2: Blurry playback
    ONLY JUDGE THE QUALITY OF YOUR MATERIAL ON AN EXTERNAL NTSC MONITOR, OR AT LEAST A TV.
    1. Disable overlays on the canvas
    2. Make sure you’ve rendered everything (no green bars at the top of the timeline
    https://docs.info.apple.com/article.html?artnum=24787
    Video playback requires large amounts of data and many computations. In order to maintain frame rate and be viewable at a normal size, only about one-fourth of the DV data is used in displaying the movie to the screen. However, the DV footage is still at full quality, and is best viewed thru a TV or NTSC monitor routed thru your camera or deck.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Beenice
    February 2, 2007 at 4:31 pm
    I am previewing on a NTSC monitor and EVERYTHING is rendered. This is why I have turned to you all. I’m totally stumped. The exported QT is no different I still have text/graphic shifts. I’ve nested the graphic/test lower third with no luck. Could this be a problem with the .psd file. I’ve tried several different .psd files with th same issue though. Weird.
    -B
  • Jeremy Garchow
    February 2, 2007 at 5:05 pm
    You have to be sure that rt effects are being rendered as well.
    Shane, you should make this a stick answer as well.
    Go to Sequence > Render All and Sequence > REnder Selection menus and put a check mark next to each option, especially the ‘full’ option. Then hit option-r (to render) the sequence. I bet FCP is displaying your PSD as a real time effect and that effect is not baked into the timeline.
    Cheers.
    Jeremy
  • Beenice
    February 2, 2007 at 5:20 pm
    I am aware of all this but isn’t a full render included into the export of a QT? The even weirder thing is that the exported QT has these funky shifts in text.
    Thanks for all your input
    -B
  • Jeremy Garchow
    February 2, 2007 at 5:24 pm
    Did you check those menus? Are those options checked? Did you then render and reexport? How did you export the movie?
  • Beenice
    February 2, 2007 at 5:47 pm
    -B
  • Jeremy Garchow
    February 2, 2007 at 7:22 pm
  • Kate Marquis
    February 2, 2007 at 7:28 pm
    beenice, does the aspect ratio for your photoshop file match the aspect ratio of your sequence?
    -kate
